GMC Safari rear lift gate struts won't hold hatch up
Received 0 Votes
I'm trying to locate the nomenclature, part number, and process for removing and replacing the rear "lift gate struts" that hold the rear hatch up on a 1997 GMC Safari. Even finding out the actual name of the item seems to be a challenge. I have a Delco part number of 510-715 but no visual confirmation. I've heard the electrical connection may be a little tricky to remove.
Autozone $44 for the hatch lift.
http://www.autozone.com/N,14300152//...eResultSet.htm
Wow, Rockauto has the exact same part for $13. Never used them, have heard good and bad, but for $31 I think I'd try.
http://www.rockauto.com/catalog/livecatalog.php
Received 0 Votes
Lift Support
All,
Thanks. Lift support, support lift, support cyclinders whatever they call them. I've found a couple of resources. Haven't talked with a dealer yet. With quick help like this, I don't think I'll need to. The van is away at college but I'll have the parts waiting when it comes home for more money this weekend!
I have a Haynes manual but it doesn't go into detail on instillation. Any ideas on more indepth instructions?
Chris
Chris
replace one at a time and you will probably need to prop the door with a dowel rod even then. i have a 97 astro and so far havn't needed to replace them. or i would have better instructions for you.
life begins when the kids leave home and the dog dies
