1995 Jimmy Multiple Error Codes
Old 09-21-08, 10:32 PM
The Service Engine Soon light in my 1995 Jimmy came on. I had it checked with a code reader and it came up with the four error codes P0135, P0340, P0141, and P1406. Is there one thing that would cause all these errors?
Old 09-22-08, 02:29 PM
HotxxxxxxxOKC's Avatar
I'm thinking the P1406 is your main cause, the EGR valve. It's mounted on your intake manifold.
Old 09-22-08, 03:57 PM
Thanks for answering. I've read where a bad EGR valve causes symptoms like rough idle and bucking on acceleration. The engine is running fine.
Old 09-22-08, 04:03 PM
You can remove the valve and clean it, and see if that fixes the issue.
Too add,
Check your alternator voltage as well. Maybe your modules are not getting enough juice. You should have 13.5 volts.
Old 09-26-08, 10:20 AM
It turned out to be a blown fuse in the Engine 1 slot that apparently powers the sensors that were returning the errors.
Old 09-26-08, 02:50 PM
Thanks for the update! Glad it's just the fuse. Now I'm gonna get you thinking, "Why did the fuse blow?".
Old 09-26-08, 05:06 PM
When I was checking out the various sensors I found some electrical connections that were in bad shape. One was barely plugged in and another was thoroughly grease soaked. Unless the fuse blows again I'm not going to worry about what made it blow.
Old 09-26-08, 07:39 PM
Sounds good! Stop by with any other questions you may have.
We will be glad to help!
Trackbacks are On
Pingbacks are On
Refbacks are On
