Finding the Squeaky Wheel
Hi all,
I have a 94 Plymouth Grand Voyager. A few days ago, I noticed a squeaking noise coming from the engine so I took a look to see where it was coming from.
The good news is that the squeak is coming from one of the pulleys over which the serpentine belt runs. The bad news is that with the overall engine noise and several suspects, it's pretty tough to tell which pulley is the culprit.
So, my question: is there a relatively simple technique to deducing which pulley is the squealer?
Thanks for any help!
Received 0 Votes
You may be able to try a mechanic's stethoscope if you have room to work with it. It's basically a long rod on a stehoscope. I've had limited success in the past locating noises with the one I got a harbor freight for a couple bucks.
Have to be real careful not to catch it in the belt or you have worse problems that a squealing belt.
pull the belt and use your hand to roll the pulleys use a stethascope to isolate the noise, most likely will be idler or tensioner, any noise from the bearing area indicates a problem with the bearing.
life begins when the kids leave home and the dog dies.
I really appreciate all the help. I'll try the techniques mentioned.
I would not be surprised to learn that it is the tensioner. I've owned two other Grand Voyagers of the same model year and I had to replace the tensioner on both of them. Unfortunately, they didn't squeak before they broke, so in this context, the squeak is a good thing.
I will also check the belt as well for wear.
Thanks again everyone!
