Climate control
Received 0 Votes
Climate control
I have a 1999 GMC Envoy 4.3L auto and no power to the climate control , fan, ac, defrost none of the settings work and this just happened one day . All fuses are good indash and engine compartment. Any ideas what could be the problem. And also totally unrelated since its been going much longer than all this started a relay under the dash on the passenger side keeps clicking while driving and intermittantly , anyone knows what this may be? Thanks.
Received 0 Votes
just because the fuses are doesn;t mean they have power check to see if the fuses have batt + with key on u may have a bag ignition switch or fuse panel both which also could cause a relay to click on and off
mech
GM had a problem with the fan control switch,s back than. they heat up and melt the connector for the wire harness on the back side of the switch and cause a draw and cause the relay to go on and off. pull it and look at the wires.
