air compressors and impact wrenches
Received 0 Votes
how do the spec-s of an air impact wrench relate to the air compressor?
i need to loosen a crankshaft pulley bolt that is torqued at 134 ft-lb. on a 1998 honda civic LX. i have a sears craftsman 1.5hp 4-gallon 4.7SCFM@40psi--3.3SCFM@90psi air compressor. i don't yet have an air impact wrench. what should i look for in terms of psi when i go to buy one, such that i can use that air compressor to drive the impact wrench to loosen the bolt? tia.
all impacts that i am aware of are rated at 90 psi, continious usage will draw that compressor down but it wil work for the way most impacts are used. i use my impacts at full psi for the compressor, no pressure regulator. if you can find one a IR is a good home impact and should hold up for all of your life just oil it good everytime you put it up if you don't use it daily.
i use snap-on but that is just because it is what i bought when i was wrenching. mine are all over 20 yrs old.
life begins when the kids leave home and the dog dies.
Torque and cfm is what you look for on the impact specs. While the cfm is probably close on all impacts, the better ones may require a little less. The higher the torque rating, the easier it will remove stubborn bolts/nuts.
I would think your small compressor would power most any impact although heavy duty use might cause you to wait on the air compressor to catch up.
