2005 PT Cruiser Fog light switch
Old 10-05-08, 08:10 AM
I put in the fog lights about 6 months ago, and they stopped working, i have checked all the wiring to the fuse box back to the switch, made sure all connections were good, checked the fuses also, they are good, bulbs are good also. I was wondering if anybody else had this problem, and could the problem be in the turn signal switch. Thanks Jim
Old 10-05-08, 10:32 AM
HotxxxxxxxOKC's Avatar
Did you wire them through a relay? I would check for voltage at the light connector. If you got 12v there, then it's your bulbs. If no power, then you have a wiring issue or relay/fuse.
Are these factory fogs you installed, or aftermarket?
Old 10-05-08, 10:38 AM
Mopar fog lights
Yes these are factory Mopar fog lights i installed, and yes they went through a relay at the fuse box.
