94 Buick Park Ave neutral switch
Hi
I have a 94 Lesabre so I will try to help if I can.
I have never did the job but I have a manual for the car.
If you can tell me what part is giving a problem then I could perhaps look at the manual and let you know what it says.
I dont want to type out the entire procedure.
Its under the cruise contol servo assembly.
Shift trans to neutral
Disconnect linkage
Disconnect connector
Remove bolts and disconnect switch
Disconnect linkage
Forgot to mention the book says if the vehicle is equipped with a Delco Loc 2 or Theftlock audio system make sure you have the correct activation cod e before disconnecting the battery
