Taurus wants to stall
2000 Taurus wants to stall on cold mornings unless I keep my foot on the gas; when warmed up, it's fine. I suspect it could be the idle air control valve. I'm going to clean it as it's gummed up. My question is- when I remove it with it still electrically connected, and turn the accessory on is the plunger supposed to move? Mine doesn't.
Thanks, Dave
Thanks, Dave
the plunger should not move unless you are on a quick decel. the iac should act the same warm or cold but try to clean it first and see how it does it may solve the problem.
good luck
good luck
