Do you have turn/hazard lights problems of 2003 Accord?
Received 0 Votes
I had both left side front and back turn light not working, and those same lights not working on hazard either. What I found was the relay that does both the turn and hazard was bad. The relay would not make the clicking sound on left turn. Relay is about $22.00 from Honda, and you will have to remove the bottom plastic cover on the driver side to gain access. That is the plastic panel that goes from the fire wall to the bottom on the dash. Honda wanted $99.00 just to start looking for the problem, it could have gone to many hundreds of dollars for them to fix this problem.
H.
H.
Received 0 Votes
I just scratched my post after rereading yours. So what you are saying is - you found and fixed it are telling everyone what you went thru, and what it COULD have cost?
