1995 Nissan Sentra!! HELP
My Car Was Cranking Slow, So I replaced the Battery, Superise Not Battery issue? Now It will not start at all, I have lights and power though! Also My Head Gasket Is leaking!! If I keep turning the key fast she will turn over very slow! Any suggestions 150670 mil 1.6LBeer 4U2
Not a whole lot of possibilities for slow cranking. If the battery was not it the other candidates would be battery cables/connections or starter. There'a also an outside chance you could have a drag on the engine from an accessory that is failing. To check that you would need to temporarily remove the serpentine belt and try cranking.
Head gasket repair will require some work. Depending on whether the head itself is damaged you would be looking at anywhere from $500-1500.
