95 Ford F150
95 Ford F150
My problem is the temperature gauge in the dash. It always shows below cold even if the engine is almost overheating.
My fan clutch went out a bit ago and it would get damn close to overheating all the time so I know that the engine was hot enough. Ive fixed that now.
I have replaced the temperature sending switch. could it just be the gauge in the dash that needs to be replaced?
Possible, but temp gauge itself failure isn't real common. Try this: Pull the connector off the sender unit. If it is a one-wire type connect a jumper wire and ground the connection. The temp gauge should peg all the way to hot. If it's a two wire type connection you can jumper between the two pins and get the same thing. If the gauge pegs it's probably okay.
I haven't checked for a dash ground yet but I pulled out my voltmeter and got a 4.6 out of one of the holes that plug into my temperature sending switch and nothing our of the second hole. I dont know what that means but power is getting to it at least partially.
I don't know exactly what you mean by jumping. Send a jolt of electricity up it to see if the dash gauge would move? I'm not sure exactly how to do that. Would I just connect the hole that had power to the ground hole with metal? the voltmeter would do that?
use a short piece of wire and connect both of the wires from the temp sender together,like the tow guy says,it should read hot, if not you've got a circuit issue ,the actuall dash connections or gauge itself would be the last thing i would check as these are inside the truck and not likely to fail,but still possible,is the engine a v8 on inline 6 ?
