ABS Check
Old 10-26-08, 11:23 AM
ABS Check
Is there a way that I can tell if my car has ABS by looking at it?
Old 10-26-08, 01:02 PM
G
it would help if you gave the year make and model,so we could tell you what to look for
Old 10-26-08, 05:45 PM
HotxxxxxxxOKC's Avatar
A ABS light on your cluster would light up for a few seconds when you start the vehicle.
If no light, no ABS.
Old 10-28-08, 03:22 PM
WTDR-DTY's Avatar
IF system is working and PCM runs test for ABS. otherwise, shine light at the angle on dashboard, so that you can see all those little hieroglifics, and see if one says ABS.
or, simply, write down your VIN, call dealer, and let them tell you.
unless you really want to take a wheel off and find out if there's a wire running into the hub.
