cracked drivers side door handle
Old 10-29-08, 09:18 AM
N
I have a 1996 Toyota Camry and the outside door handle is cracked and won't open without reaching underneath the door handle. Can I repair this by gluing the handle back together or would I need to replace the door handle. Assuming I need to replace it, does this involve removing the outside part of the door frame? Thanks.
Old 10-29-08, 02:43 PM
the_tow_guy's Avatar
Received 181 Upvotes on 143 Posts
Skip the glue, it won't last. The outside handle is replaced by removing the inner door panel. Then you work through an access opening in the door. The handles are not as expensive as you might think and you can get them in colors to match your existing paint from Toyota. If you go ahead and get the replacement handle it will help you to see how it mounts. If you don't care about color, you can get one really cheap:
http://www.ezbodyparts.com/buy/index...AMRY&year=1996
