How to Check Coolant Hose Leaks
Old 10-29-08, 10:54 AM
D
How to check coolant hose leaks if it can't be easily seen visually? I saw a mechanic attached a tool onto coolant filling neck (after removing cap) and pump air(?) in. If you can post a link to where I can find this tool, that would be great. Thanks!
Old 11-27-08, 09:03 AM
mikeTN's Avatar
Received 1 Upvote on 1 Post
Exclamation
Autozone has flushing kit that you may be able to use for what you want to pressurize the system. Don't OVER PRESSURIZE IT!! If not, they may rent a tool for that.
Old 11-27-08, 12:58 PM
Speedwrench's Avatar
what you are looking for is called a cooling system pressure tester. avaliable at most auto parts stores.
life begins when the kids leave home and the dog dies
Old 11-27-08, 07:03 PM
the_tow_guy's Avatar
Received 176 Upvotes on 138 Posts
Old 11-28-08, 12:04 AM
D
Thanks for all replied! Found the leak and fixed it already.
Old 11-28-08, 08:51 AM
You passed up a perfectly good opportunity to buy tools??? Turn in
your DIY card!!!!
Old 11-30-08, 03:57 PM
R
cooling system leaks
No doubt a married fellow. RW
