92 Sundance turnsignal not blinking
Gotta 94 Sundance that when you put the turn signal on , the light eluminate but they don't blink . is the blinking function in the turn signal switch that is attached to the lever ? I saw them on ebay for around $50 bucks , also is this a pain to swap the old for a new one on the column ?
sounds like the flasher relay is stuck closed and no it is not part of the switch......The hazard warning flasher is located on the relay module. The relay module is adjacent to the fuse block....the fuse block is located under the instrument panel to the left of the steering column.
