spark plug wire order on chevy 4.3 v-6 distributor
I was in the process of changing the distributor cap and spark plug wires on my s-10 4.3 v-6 and pulled the wires off of the cap before I got them marked, I need to know the correct order to put them back
It has the HEI Distributor
tow-guy is correct with 1 being to the right side looking at the engine...(don't ever assume that with the new engines)...cyl one is the closest spark plug to you....best way to know......on the distributor 1 is the closest to you just to the right....good luck
Must be a "Z" engine as the "W" and "X" engines (VORTEC) has that funky lookin cap with the plug #s stamped in it........
If'n it's a "Z" Tow man's right on
