1996 Mercury Marquis Blend Door Replacement
Old 11-09-08, 03:17 PM
Hi, Trying to replace the blend door actuator in father mercury. I need the steps on how to replace this item. Thanks, Mark
Old 11-09-08, 07:09 PM
HotxxxxxxxOKC's Avatar
Might stop by the local library for a Haynes type manual to help you.
My coworker just had to replace his on his 96 Sable and the entire dashboard has to come out. Not fun!
You can get down and look underneith the dash and see if you can remove it without taking the dash out. It will have a square base, with a round/short tube with e wire harness going to it. It will be right above the heatercore box.
Old 11-10-08, 05:10 PM
I checked the Factory manual and the instrument panel does have to come out,the blend door is on top of the air distrubution box. For an experienced tech it would take about 3-4 hours, a novice probably 6 hrs.
good luck
