1999 Jeep Cherokee
1999 Jeep Cherokee
1999 Jeek Cherokee, 4.0, 119K. Should front hubs stay ingaged while vehicle is in 2WD.
I don't know about your 99 but my 1990 cherokee has full time hubs
The front drive shaft will disengage but the axles still turn
Backing up and sometimes turning the wheel a little will help to disengage a stubborn transfer case.
The hubs stay ingaged but the front drive shaft does not. Is there a vacumn shift motor or control switch that could be defective? Thank You.
After looking at some diagrams, your vehicle does not have a motor/vacuum controlled hubs.
Your hubs and bearings are one assembly. If you are getting groaning type noises, you need to replace the hub assembly.
