Cranking a Stored Engine
Received 0 Votes
I have a VW buggy engine on a project car that has not run for seven years. Are there any precautions I should take before cranking the starter?
Received 0 Votes
I would turn it over a couple revolutions first
Check oil level
After it starts, if it does, then I would watch it close looking at the gauges.
Lightly rev up and down a bit to gently flex the rings.
Run for half hour if things are good then change engine oil
Check oil level
Any clean engine oil will do. Couple of squirts in all cylinders and then follow frankiee's procedure. If you leave the plugs out for the initial turn-over you can either hand rotate it or spin it with the starter.
Fresh gas?
Fresh gas?
Please use fresh gasoline. What is in the carb(if any) is shellac by now. Drain the tank and add some stabilizer to minimize the moisture that is surely there. I like to crank it over with the plugs out, and oil in the cyl. as stated, until the idiot light goes out or the guage goes up. That way I know I have oil pressure. Wouldn't hurt to check the plugs, points(if applicable) and voltage to the coil. A compression check wouldn't hure either, to ensure the valves are not stuck. Luck to 'ya.
