hyundai rear strut removal
Old 11-29-08, 06:53 AM
1996 Hyundai Elantra Can anyone tell me how to remove stabilzer nut on rear strut on a Elantra I can't figger out how to keep bolt from turning
Old 11-29-08, 06:58 AM
HotxxxxxxxOKC's Avatar
You DO NOT remove this until you have the entire assembly out of the car under a spring compressor.
With it compressed, you will take another wrench to hold the shaft while you turn the nut.
Add:
If that doesn't work, have your spring compressor clamps on loose enough so the spring will not decompress, but tight enough so the pressure will allow you to turn the top hat bolt. Kind of hard to explain.
