where is the abs relay
I have a 99 Ford Explorer with the abs light on. I want to check the relay but I dont have the owners manual to check location. Also, how can I check the abs codes. will an obd II tester do it or is there a tool I can buy at an autoparts store.
Received 0 Votes
there is no abs relay on this vehicle, in the battery junction box check fuses #7 mini 30a,#3 50a maxi, in the fuse junction panel under the dash check fuses # 14 10a mini,#9 7.5 mini, the problem that I have seen most on these is the sensor for the rear wheels that is in the rear end housing.
good luck
good luck
