brake pads on jeep cherokee
Old 12-05-08, 07:40 AM
C
Is it difficult or is there anything special to changing front brake pads on a 2001 jeep gran cherokee?
Offered to help a friend do it to save him some $$$
Old 12-05-08, 04:28 PM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
Cake walk my friend. It will take you longer to remove the tires then to replace the pads.
Remove the caliper bolts and pull the caliber off the bracket and support it. Pop out the pads, install new, and grease the glide pins (the bolts you removed).
Old 12-07-08, 08:15 AM
C
Sounds exactly like my 95 altima. Takes longer to do the 'niceities' than the actual pad replacement.
Thanx
