Noisy clutch
Old 12-10-08, 08:30 AM
R
Noisy clutch
Folks:
I have a 2004 jeep rubicon. There is 31,000 miles on it.
This noise only occurs during cold weather.(below thirty)When
its warm no noise. When I depress the clutch or let it up I'm
hearing a noise that sounds like a bad spring.I got under
the vehicle and the noise seems like it's inside the bell housing.
I was going to take the jeep to the dealer but since it got warm I can't duplicate the noise so they can hear it to trouple shoot.I would appreciate any and all help. Thank you in advance Ron
Old 12-10-08, 08:43 AM
mikeTN's Avatar
Received 1 Upvote on 1 Post
Question clutch noise
Hard to say exactly. Was the vehicle running when you checked the noise? Does it do it when the motor is not running? Could be a spring in the pressure plate, depending on how the plate is made(springs-coil or finger type springs). Could it be the return spring for the clutch pedal itself? Not much help I know, but I can't imagine it only when it is cold. Is it a hydraulic type clutch or mechanical? Someone else with more knowledge of Jeeps will check in shortly. Good luck!
Old 12-10-08, 09:51 AM
R
noisy clutch
The noise only happens when the motor is running.I believe
it's hydraulic clutch. thanks for your reply Ron
Folks I was wrong the noise was there even when motor was off. I answered before putting brain in gear! RON
