2001 Chevy Impala - A/C-Heater motor?
Old 12-15-08, 07:38 AM
D
Hello all,
My air and heater motor do not work on settings 1-3, and then work when turned to 4, always. I would assume it s a motor problem but may be very wrong. I want to be able to fix this myself, so if anyone can lead me in the right direction with what part, or how to tell what is actually wrong. Thanks everybody.
Old 12-15-08, 07:50 AM
the_tow_guy's Avatar
Received 176 Upvotes on 138 Posts
Possible faulty resistor; it is what controls the amount of voltage that reaches the motor and determines the speed.
Old 12-15-08, 07:57 AM
D
resistor
I am not by my car so I ask "is this something the owners manual can tell me how to replace"? Is the resistor inexpensive enough for it not matter if I fix it and it doesn't solve the problem.
Old 12-15-08, 08:31 AM
My Mitsu same as your Impala?
Thanks TTG... I have a similar problem. My Mitsu Lancer 04 started spitting out water under the passenger side dash last summer while my AC was running and then about 2 months later the blower stopped working on "1-3" (correlation?) but still has normal/optimal functioning (no decrease in heat or blowing capacity) while on setting "4"--same as the Impala.
FYI: I also read on a different post on DoItYourself.com, that it may be a faulty Blower Motor Resistor?
Old 12-15-08, 09:59 AM
D
So the question becomes, where would I find out how to replace my blower motor resistor? My owners manual seemed to be no help. Is their a website like this that might have a tutorial. I will also google it and let everybody know what I find.
Old 12-15-08, 10:31 AM
A
Found this for you. It might be helpful.
01 Impala heater blower resistor - Automotive Forums .com Car Chat
Aces
Old 12-15-08, 01:06 PM
D
Bmr
That was extremely helpful, I am going to try it! Thanks again
