2001 Ford Escape start problems
Old 12-19-08, 10:42 AM
i have the 6 cylinder version. I have replaced the plugs, wires, gaskets/o-rings and bad coil (code p0351). it will barely turn on and will shut off within a min. there are no codes. It is hesitating with a popping noise. I can not press the accelerator cause it will shut off. I hear the fuel pump come on. all lines have been checked and all hoses also. any ideas from anyone?
Old 12-19-08, 03:05 PM
B
I'm thinking electrical: Popping noise could be incorrect timing; are you sure plug wires are installed in the correct order? May be camshaft or crankshaft position sensor if it has them.
