Silicone and antilock brakes not compatible?
Old 12-20-08, 09:30 AM
Question Silicone and antilock brakes not compatible?
I’ve heard many people say that you shouldn’t use silicone brake fluid and antilock brakes systems. I was wondering if anyone knew the reasons why; if so Please elaborate.
Old 12-20-08, 09:59 AM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
Never even heard of it. I would only use brake fluid approved through the owners manual.
Old 12-20-08, 02:41 PM
G
Received 2 Upvotes on 2 Posts
Silicone brake fluid is commonly called DOT 5.
Old 12-20-08, 04:41 PM
Speedwrench's Avatar
the only reason not to use dot 5 is if you don't start from a totally clean system you can have corrosion problems due to the residue of dot3 fluid that was in the system before, dot 3 is hygroscopic and if any remains in say wheel cylinders or master cylinders it may cause corrosion with out being discovered until a real problem develops. also dot 5 is not compatible with all rubbers used in some brake systems, dot 3 is alcohol based and dot 5 is silicone based so not all systems will have compatible rubbers and seals.
life begins when the kids leave home and the dog dies
Old 12-21-08, 10:48 AM
B
Old 12-21-08, 03:51 PM
good post bob22, the first five i already knew about, the second was new to me and good info.
