Wiring question
Old 12-22-08, 03:46 PM
Wiring question
I ordered a 6 position fuse block with a cover to run lights/CB radio off of (see pic below).
The box has 6 positions and a "in" and "out" connection for each fuse. My question is, can I run one wire into the first position and then do a little jumper wire off of that into the next 5 (to avoid running 6 12v wires from the battery)
I currently have an extra fuse box, but wanted this one because it has the cover...
Old 12-22-08, 04:02 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
As long as the wire can handle the total load of all the accessories you plan on putting on the block, sure. It may be a rather large wire considering your load, so judge it carefully. I would solder a wire from one to the other, and your hot wire to the last one with the beginning jumper.
Old 12-22-08, 04:09 PM
The main wire will be 6awg and the jumper will be maybe 12 or 14awg..
I will solder the jumper to each of the 5 terminals and then to the hot terminal./..
I guess this will be sufficient??
