Need advice on overload struts
Old 12-24-08, 08:25 AM
My wife is disabled and we had a power chair lift installed that is mounted on the back of her 2005 Toyota Highlander.The lift is over a hundred pounds the chair a little over 200 and I dont know about the class 3 hitch.
With all this weight hanging off the rear of the SUV I noticed some sag.I dont want the rear end lower then the front .
Any advice?
Old 12-24-08, 11:41 AM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
You're gonna need some stiffer springs I'm sure. What kind, I'm not sure. Since it looks like this vehicle has independent rear suspension, leave springs can't be used. Have you called a local handicap vehicle retrofit outfit? I wouldn't have them do it, since they are usually very expensive, but maybe they can offer you ideas.
Old 12-24-08, 12:01 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
Air spring kit maybe? I'm sure they make them...well, I would think they do anyway...
Old 12-24-08, 12:26 PM
Got a lead
Thanks I called the place that installed the lift and they gave me the company they use here in Fort Worth for spring service.
I called them but they are closed so I will try after Christmas.
I got to do something because today I put the chair on and it looks like I have bags of cement in the back.
I am sure if I drive at night my lights will be off.
Will let you know what they say.
