thermostat replacing
Old 12-26-08, 03:23 PM
D
2003 chevy impala coolant drain plug where is it
Old 12-26-08, 06:05 PM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
If you are just replacing the thermostat, you don't need to drain it. When you disconnect the thermostat housing, it will drain on it's own.... won't be that much.
Old 12-27-08, 08:28 AM
R
Drain plug
The drain should be on the driver side bottom of rad, well hidden and very delicate. If you ruin it you pull the rad. You can do as Okie says or if you want to save coolant loosen lowe rad hose.
