2000 silverado,trans-transfercase problem
Old 12-27-08, 06:54 AM
Unhappy 2000 silverado,trans-transfercase problem
hello,ihave just taken out my transfercase in my 2000 silverado and put in one with 50k on it,after completing it,now when attempting to go it just revs up and hardly goes,(kind of like a high stall) all fluids good .and also souds like there is a clicking noise(somewhat like a gear or something like that isnt engaged all way).dont know what i could of done wrong,all worked perfectly before.it has the push button system in it.(never no problem ) any ideas to check or what went wrong?any help appreciated.thanks
Old 12-27-08, 07:05 AM
HotxxxxxxxOKC's Avatar
Something isn't lined up correctly. If the other one was fine, why did you swap it?
Did you connect all the wiring correctly?
Old 12-27-08, 07:15 AM
the old one had 220k on it and was making a clunking noise inside and i got this one with matching motor but just now got time to install it, jjust cannot figure out what went wrong?also after doing the swap i noticed that the ABS&BRAKE light are on in addition to this other problem. i believe that all the plugs r back on right as they can only go back to the right ones.(i hope) u mentioned that smthng not ligned up right?is there a special way to put baclk in? didnt seem like i had to force anything flange went up tight and so on? thanks for more ideas if have any.
Old 12-27-08, 07:16 AM
Your VSS sensor is messed up. (vehicle speed sensor)
It's mounted on the transfer case.
Old 12-27-08, 07:28 AM
is that one of the plugs that i had to undo to remove and replug when i swapped the cases? the only other thing i did was the newer case did not have the engager on it and i had to put it on from the old one.(i assume that is what it may be called) and the vss you talk of ,that would cause it not to shift out of high and rev up?thanks again
Old 12-27-08, 07:49 AM
can that be tested while still on the vehicle or does it need to be taken to dealer?thanks
Old 12-27-08, 08:10 AM
You should be able to remove the sensor from the transfer case. Get a voltage tester (multimeter) and put your a wire lead from the tester on each pin (A & B). While doing this, spin the speed sensor pinion doohickie and there "should" be .5 volts AC.
Your truck auto or manual?
