cylinder location on 99 continental
My mom's 1999 lincoln continental is misfiring on cylinder 4. I'm going to replace the ignition coil and plug on that cylinder, however I'm not 100% sure which cylinder it is.
I think it is the one against the firewall on the closest to the drivers side.
firewall
1 2 3 4
5 6 7 8
front of car
Does anyone know if these cylilnder numbers are right?
Thanks
firewall
1 2 3 4
5 6 7 8
front of car
Thanks
Per Autozone
AutoZone.com | Vehicle Selection - Year
This is a little confusing, since they don't reference the body...but go by where the coil packs are and you should be ok.
I started take the sparkplug out, Ive turned it about 2 turns sofar, it is way too tight coming out. It is taking much more torque to come out than it should. The engine is cool. I pulled my socket out and it was covered in oil. There is about an inch of oil in the bottom of the spark plug cylinder. The plug is still in.
car has 67K miles
Any idea why there is oil in the spark plug cylinder, or why it is so tight to take out?
car has 67K miles
Mark, dunno what happened, it wasn't when I posted...and now it's coming up as a F250...lol. Somehow it's pulling different things from my vehicle list. Oops, won't do that again.
Guess I should have just said, check Autozone for your car under "Specs" and "Firing order".
Passenger side from in front of car, from front to back, 1,2,3,4, & drivers side front to back from front 5,6,7,8.
Hint: when looking for #1 cylinder,on a v-6 or v-8, it will always be at front of engine on side that the cylinder head sticks out a little further toward front than the other.
