2000 buick lesabre
2000 buick lesabre
air shocks/load leveler motor is not shutting off shocks are full of air any suggestions
Follow your air lines to the valve with a little arm/lever on it,( height sensors) one of those levers is probably stuck in an upward position even slightly. There should be adjustment on them, but just check & see by pulling down & up on them for partially seized.
