how to replace head gasket on chevy Venture.
Old 12-28-08, 07:55 PM
E
where can I get instruction to replace head gasket on chevy Venture? Please don't tell me get a mechanic. I know is complex and time consuming that why i am looking for easier way. I know what is involve. thanks for your help.
Old 12-29-08, 04:27 AM
W
If you've never done this before............GET A MECHANIC.....That being said, please read what the fella with the 3.1 went through while replacing his intake manifold gasket.
You're gonna go through the same procedure PLUS removing the exhaust manifold and then the head. This would be scarey for a 1st timer if the engine was in a car where you can see both heads ...........but in the Venture, you're gonna have to rely on your sense of "feel" to get half the stuff off the rear head.
I'd set up a big bench to place removed parts and the bolts that secured them.......and in some sense of order as sequencing reassembly on these engines is critical.....
Be CAREFUL as valve pushrods are TWO lengths........Put the wrong one in the wrong place and you get to do the job twice
Good luck!!!Beer 4U2
Old 12-29-08, 06:27 AM
the_tow_guy's Avatar
Received 251 Upvotes on 203 Posts
I agree with wrench, but if you're set on doing it:
AutoZone.com | Vehicle Selection - Year
Directions for removing the associated items can also be found there as well.
Pay particular attention to learning about torque-to-yield head bolts.
Old 12-29-08, 07:49 PM
You MUST replace the head bolts.
Old 12-29-08, 10:02 PM
C
Remember you can tilt the motor, buy rent or steal the tool, life is alot easier that way.
