1999 cougar 2.5 liter v6
Old 01-06-09, 10:20 AM
W
can someone tell me where the fuel delivery module is located on this 1999 cougar.there was a recall for this but i think time has run out.this is my daughters car & she will be driving down road & its will start to act as though she is running out of gas & will eventually shut off.she will have to pull over & restart & it may do it again or it may not.seems to be worse at the problem above.can i change this module out & if so where is it located. thanks for your help
Old 01-06-09, 05:59 PM
G
the fuel module is in the tank. you should call the dealer with the vin and see if the recall is still open on your car
Old 01-06-09, 10:24 PM
W
fuel module
can you please tell me if the fuel module is on the fuel pump or seperate from pump.we have replaced fuel pump.
thanks for your help.
Old 01-07-09, 06:44 AM
G
the fuel pump assembly is the module.good luck
