2000 Ford Windstar Turn Signal
I have a '00 Ford Windstar and the right front turn signal light is not working. I have changed bulbs, checked the fuse and do not know why it still isnt working. The right front headlight works but there is no turn signal bulb working. Can someone please let me know what may be the problem?
Thanks,
niceguy4u36
Thanks,
niceguy4u36
I trust you looked at the rear right turn signal, and it was working. Clean the contacts in the socket as well as the inside of the socket shell. A test light or a volt meter would be a big help.
Yes the rear one works fine, I will clean the contacts tomorrow and see what I get with that...thanks
try turning on the hazard flashers, if the lamp still won't light up you have either a wiring problem or a bad turnsignal swich, next try to gain access to the connector to the turn signal switch, probe the wire to see if current is coming from the switch. if the switch is working then the problem is most likely a socket or wire connection.
life begins when the kids leave home and the dog dies.
