99 Chevy Suburb leaking Coolant
Old 01-10-09, 06:23 PM
C
I layed under the vehicle to see where the leak is coming from.Its a 99 Chevy Suburban 1500. When I pour coolant in the recovery tank I can hear it leaking out as I pour it in.
l have only driven the vehicle in the last 4 days about 2 or 3 blocks always early morning or aftersunset (when its cold outside) and the heating temp will be at the half way mark.
I have noticed a huge cloud coming from the muffler. Dont know if its the car being cold or something else.
When I checked the oil it looks to have water in it.
Help appreciated, thanks.
Old 01-10-09, 06:36 PM
the_tow_guy's Avatar
Received 241 Upvotes on 194 Posts
If you hear coolant leaking out when you pour it in the recovery tank you have to have either a crack in the tank or the hose from the tank to the radiator has to be leaking. Your other symptoms sound very much like a blown head gasket or leaking intake manifold. Your oil has a milky tan color to it? Normal to have some steam in the exhaust when first starting up, but it should go away when things are warmed up.
Old 01-10-09, 07:03 PM
C
Yeah the oil is milky tan in color.It has about 110k on it.When I had it smogged the guy said my hose had a leak.
Oh and I had the water pump replaced in March of 08.
And the alternator changed 2 months ago. Are these vehicles normally lots of problems?
Thanks
Old 01-10-09, 07:53 PM
Speedwrench's Avatar
no most of the suburbans that i know about have been very dependable vehicles.
Murphy was an optimist
Old 01-11-09, 07:52 AM
mr_franksmith's Avatar
Greetings
First thing I would look at would be the Intake manifold leaking
internally. It is possible you have a blown head gasket.
