car wont start
Old 01-12-09, 09:53 PM
F
car wont start
I have a 1986 toyota camry 4 cylinder engine 2sE . During th emonth of dec. 08 did not drive for a bit used hubbys car. My car was started weekly. My husband went to start it and nothing. It has gas, spark, no moisture, battery is charged. it turns over but will not start. I have no clue..someone help?
Old 01-13-09, 07:27 PM
Speedwrench's Avatar
check the fuel pump delivery to the engine, could have bleed off and in that case it might take several tries to deliver fuel to the injectors.
if we're not supposed to eat animals why are they made out of meat?
Old 01-13-09, 09:43 PM
F
Red face simple fix
My car would not start so we pulled off the distributer cap and a small metal piece had fallen off the rotor. It was put back onand wow it started.
Old 01-14-09, 05:05 AM
the_tow_guy's Avatar
Received 251 Upvotes on 203 Posts
Along speedwrenchs line of thought, listen at the gas cap while someone turbs the key on (not "start") to see if you can hear the pump running.
Also you may want to check that the timing belt is intact.
Old 01-14-09, 05:13 AM
if you didn't replace the rotor you will need to do that small metal piece will fall of again.
