reading codes on OBD1 Sentra
Old 01-15-09, 08:25 PM
R
I've searched high and low and i'm looking
for an easy way out. i need to pull the codes from
my 94 nissan sentra. i know you can pull the ecu and
get the led's to flash but, right now we are in a deep freeze
here in the NE. I've heard people talking about using a paper clip to pull the codes.
anyone have the steps to do this.
thanks
bryan
Old 01-16-09, 04:56 AM
the_tow_guy's Avatar
Received 251 Upvotes on 203 Posts
Old 01-17-09, 03:35 PM
R
Originally Posted by the_tow_guy
thanks tow i was hoping for an easy way out.
looks like i'm doing it the hard way.
Old 01-22-09, 05:35 PM
R
ok i broke down and read the codes.
it came up 32 egr function. i failed my state emissions with a double allowed NOX reading. I checked for rotted hoses to the egr but all were fine.
i have an haynes manual which does a bad job of telling how to replace the egr or even clean it.
does anyone have some good steps with step by step pictures.
i tried autozone but even they were not very involved.
sorry for all the questions i'm nervous about doing.
Old 01-22-09, 05:55 PM
Old 01-22-09, 06:49 PM
R
i tried autozone but i was hoping for a better detailed steps.
only because haynes says one thing and autozone says everything can be done from the top.
thanks
Old 01-23-09, 04:30 AM
Could buy a subscription on AllData.com; that's the same stuff the pros use.
Old 01-24-09, 05:17 PM
R
thanks tow.
is there a free alldata subscription. i know i'm cheap
Old 01-24-09, 05:49 PM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
Originally Posted by risoworker
thanks tow.
Nope...............................................
But here's the factory service manual. You will have to download each file. Each file is a separate system. The IDX.pdf is the index.
Index of /FSM/Nissan/Sentra/1994
Normally they group it all into one file, but anyways.
Old 01-25-09, 01:23 PM
R
thanks hot.
i read the ef and ec section but they only talk about testing the valve.
did i miss the replacment procedure.
that link is impressive thanks.
