99 grand 3.4l intake gasket advice on changing
1999 Grand Am Se
3.4l v6
140,000 miles
I have a 99 grand am that is leaking antifreeze. From the research I have done it seems to be a very common problem for the lower intake manifold to be bad. I would like any advice on changing the gasket. I have read thru repair manual and just wanted to see if there are any shortcuts or tricks when changing the gasket. Any advice would be greatly appreciated.
3.4l v6
140,000 miles
For you I would recommend just following the manual. There is a short cut by not removing the rear valve cover and slipping the intake manifold out from under it. But you are going to have a hard time getting the pushrods out.
