99 Winstar no heat
Old 01-23-09, 06:09 PM
99 Winstar no heat
1999 Ford Winstar Van, automatic, v6
My heater didn't work sunce I started it this morning. It blows cold air only and the blower works fine at any setting.
Is there somethin I chck myself (like a fuse or broken hose) or should I take it to the shop?
Old 01-23-09, 07:17 PM
mowermonkey's Avatar
Whats the heat guage reading on the dash? Is the radiator full of anti- freeze? The radiator now not the plastic over -flow jug ! check it out
Old 01-24-09, 05:48 AM
the_tow_guy's Avatar
Received 242 Upvotes on 195 Posts
Problem possibly with the blend door that controls output air temp. That would be only moderately DIY-able.
Old 01-24-09, 03:08 PM
The heat guage was exactly in the middle between hot and cold. I saw it in the morning and evening yesterday. I'm not sure where the radiator is but the overfill looked empty and rusty (dirty). I added anti-freeze up to the fill line.
tow_guy - thanks. If its that its beyond me to repair.
Old 01-24-09, 05:44 PM
A
Feel the ends of the heater core where they come out of the firewall into the engine compartment. If one is quite cooler than the other you most likely have a clogged heater core.
