Brake/Caliper Problem
Old 01-28-09, 08:14 PM
B
I have a 95 eagle talon that the front brake or caliper stick and locks up on the driver side. I've replaced the caliper and it's still doing the same thing. Any suggestions..
Old 01-28-09, 08:29 PM
W
does your car have antilock brakes?
Old 01-28-09, 08:58 PM
the_tow_guy's Avatar
Received 241 Upvotes on 194 Posts
Might want to gamble and replace the brake hose on that side. When they fail internally it will cause the fluid pressure to be retained in the caliper after stopping.
Did the Talons offer ABS?
Old 01-29-09, 05:21 AM
W
did not think about the hose Tow Guy, thats where I would go first.
Old 01-30-09, 04:23 PM
WTDR-DTY's Avatar
95 Talon is Eclipse, and we have one sitting in garage now.
I'd say, remove brake line from the caliper and master - sorry, I know, it is VERY crammed under the hood - and blow it with compressed air. Lines are very small diameter inside, impurities can clogg them fast. Also, chance is it's bent/kincked somewhere... Lines are not that expensive to replace, just bleed the system well after.
How is the opposite side rear caliper doing? no problems? Cuz if both of them have sickness, it's your master.
Old 01-31-09, 12:57 PM
Gotta go with the hoses, been there, done that.
