Fog Light?
Old 01-31-09, 06:34 AM
B
Fog Light?
Hi,
I have a 97 Maxima,I changed the fog light but it still doesn't go on. I checked all the wiring. I am stumped. Anybody?
Old 01-31-09, 06:55 AM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Have you checked the inline fuse, or the fuse in the fuse block? How many fog lights do you have? If two, does one work and the other not? Unclear.
Old 01-31-09, 07:56 AM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
You've seen cars with only one fog light?
Old 01-31-09, 08:37 AM
G
Received 2 Upvotes on 2 Posts
My Toyota's fog lamps will only light when the headlights are in the low beam setting. Don't work by themselves or with high beams or parking lights. Is the Nissan setup similar?
Old 01-31-09, 11:30 AM
If one works, and one doesn't, you need a new fog lamp. The two are wired together.
Old 01-31-09, 01:15 PM
B
The one on the passenger side is on. Driver side is out. I bought a new bulb and installed it,but it's still is out. I am stumped.
Old 01-31-09, 01:45 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Make sure the ground to the light is good. May have a separate ground wire be sure that's good.
