Cam position sensor 99 Chevy Venture Van
Old 01-31-09, 04:13 PM
xpogi's Avatar
Anybody know where the cam position sensor is located on a '99 Chevy Venture Minivan? How easy is it to replace?
Old 01-31-09, 04:29 PM
HotxxxxxxxOKC's Avatar
1. Disconnect the negative battery cable.
2. Remove the serpentine belt.
3. Remove the water pump pulley, if necessary.
4. Remove the power steering pump assembly, if necessary.
5. Detach the electrical connector.
6. Remove the retaining bolt, and extract the sensor.
Old 01-31-09, 05:19 PM
xpogi's Avatar
Thanks. Just what I needed.
