cv axle on a 1989 plymouth voyager le
Old 02-01-09, 02:04 PM
new to this site, hope someone can help me. i have the 32 mm nut off the hub and the bolt that goes horizontaly thru the ball joint out. how do i get the control arm loose so the brake assmbly will swing free. and how do i get the axle out from there? pls. help! thnx
Old 02-02-09, 04:30 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
use a large pry bar and push down on arm should slid off stud. If rusty use wd 40 or some rust buster. Axel may have to be pried out of differential.
