96 hyhundai Elantra Brake prob
Old 02-04-09, 09:28 AM
son has a 96 Elantra that keeps losing brake fluid then loses brakes Have replaced drivers side rear brake cylinder and master brake cylinder can't find any other leaks but still losing fluid ,when I pull tires its dry around cylinders and caliper Am completely stumped ANY IDEAS OR SUGGESTIONS PLEASE ?????
Old 02-04-09, 10:07 AM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
No expert...but could it be leaking out the master cylinder? Had a car once that was doing this..turned out it was being sucked into the vacumn booster and into the engine.
Check under the dash, could the fluid be leaking to the interior somewhere?
Also saw on another thread here that some cars share the hydraulic resevoir for brakes and clutch. Manual trans? Hydraulic clutch?
Just some thoughts til a Pro shows up....
Old 02-11-09, 08:08 AM
Is it possible for the proportioning valve on a elantra to leak??I have changed master cylinder and 1 wheel cylinder on sons car but he still has a fluid leak some where.Hand has come away wet with fluid after rubbing bottom side of proportioning valve but am not sure if this is from overfilling fluid and spilling some in master cylinder bowl,car loses about 100 ml of fluid every day or 2
