stumped
Old 02-12-09, 09:50 PM
A
stumped
just changed engine in a 2000 intrepid 2.7. now i'm done it won't start. i've checked everything a 100 times and it's all in order. two things come to mind one being the new engine is 2 years newer and the other is the fuel regulator looks different. any ideas?
Old 02-12-09, 10:15 PM
K
there could be many problems...was the engine new or used is the first main question
Old 02-12-09, 10:47 PM
A
the engine has about 50000km. it comes from our insurance salvage and would have been bench tested.
Old 02-12-09, 11:12 PM
K
what year is the used engine???
Old 02-12-09, 11:16 PM
K
sorry it's 2 years newer.....I would try and remove the camshaft sensor connector, the one on the on the front (right side of the engine) and crank the vehicle it may take a long time to start if it does. I'm trying to figure out if you have the wrong engine installed....one engine may be a NGC and one may be SBEC,
Old 02-13-09, 09:07 PM
A
today i have changed the fuej rail,injectors,coils,plugs,cam sensor, still nothing. all thats left is crank sensor and ecm. i looked under the dash and found a fried ground wire for the remote starter. someone must have hooked jumper cables up backwards.can't be good for it,maybe took some life out of ecm, what do you think ?
Old 02-13-09, 09:17 PM
K
why was the engine replaced anyways, have you tried to remove the cam sensor connector and start the vehicle......I would also try that and let me know.....
Old 02-13-09, 09:46 PM
A
the car was stolen and a bearing spun but it was still running. i did try starting it with the cam sensor unpluged, maybe not hard enough
Old 02-13-09, 10:08 PM
B
any codes does it have fire or inj pulse?
Old 02-13-09, 11:52 PM
K
i would try with the cam sensor unplugged crank it for 10-15 secs if it doesn't start. re-post...and we'll investigate further.
Old 02-16-09, 09:22 PM
A
thanks for t he info, unpluging the cam sensor was the ticket. now what? does it need a different ecm?
Old 02-18-09, 10:05 PM
K
sorry to tell you but you have the wrong engine installed...or at least the wrong cam sprocket...there is a certain year that chrysler has change the pcm from sbec to ngc. the cam sprockets have different slots in them for different firing. If your energetic you can start to disassemble the old engine and remove the cam sprocket and install it on this engine..
Old 02-19-09, 06:02 PM
A
thanks for the advice. the car has now gone to the dealer. appreciate your help and will certainly keep that problem in mind.
Old 02-19-09, 10:22 PM
K
youe welcome, re-post what the dealer says
