1994 Dodge Ram Brake light problem
Old 02-17-09, 12:38 PM
G
I have a 1994 Ram 1500 that doesn't get driven much anymore. The last time I used it the light that would normally light when the parking brake is engaed stayed on. I also had a constant ABS light staying on. Any ideas?
Thanx
Old 02-18-09, 04:50 AM
B
the red brake light is usually used for multiple things other than the park brake it can be used on the fluid level sensor or combination or centering valve, would start by checking fluid level and if its low would fill and check for leaks for a starting point.
if its not low on fluid would suggest you have the codes read on the abs to get a starting point, on diagnossing the problem you may even want to see a shop to have it diagnosed.
