1995 altima wheel bearing replacement
Old 02-19-09, 10:43 AM
C
Can I replace a sealed front wheel bearing at home or do I need to take it to a shop to remove old bearing and re-seat the new sealed bearing?? I have not tried to take apart the axle/front end to look--I have only refered to the haynes manual.
Old 02-19-09, 12:39 PM
Received 30 Upvotes on 29 Posts
You can do it if you are a pretty good DIY'er, but it's less hassle to pull the hub (I think I would do both fronts), take them to an auto parts store that has a press and let them push the bearing out/in.
