brakelines 97cavalier
Old 02-20-09, 05:43 PM
T
New Member
I need to replace the rear brakelines on a cavalier...Do I just cut a piece of the old line off and take it to the part store to match it up..should I piece the lines together or replace it as one piece?...any other advice would be appreciated..Thanks
Old 02-20-09, 06:05 PM
P
If you're talking about the steel lines, then yes, the entire line would need to be replaced. If it's ABS equipped (likely), there is a hydraulic modulator hanging off the master cylinder with 4 lines coming out of it. Replace the line from there back. You won't find a single line, so just make sure and use UNIONS to connect sections.
