2000 Ford Expedition XLT starter relay
Old 02-23-09, 03:05 PM
E
I have 2000 Ford Epedition when I turn the key on, I get one click and the car will not start. I replaced the battery and still the same problem. Could you Please tell me what the problem might be and were the starter relay is located.
Thank You.
Old 02-23-09, 03:20 PM
L
Be sure the wire connections both at the battery and at the starter are clean & tight
Good luck and have a great day
Old 02-23-09, 03:45 PM
E
Thank You for your reply put in new battery and connections are clean and tight same with starter.
what else can I check.
Thank you.
Old 02-23-09, 03:50 PM
the_tow_guy's Avatar
Received 251 Upvotes on 203 Posts
Not sure where exactly it would be mounted on an Expedition. Pretty easy to find, though; just follow the positive cable off the battery.
More info here:
AutoZone.com | Vehicle Selection - Year
Scroll down the page for the Relay (solenoid) info.
If you are getting a solenoid click either the solenoid is not making proper contact internally (or you have a bad connection as liljman has suggested) or it is and the starter motor is shot.
If you can get close enough to the starter to hit it, you can try tapping on it a couple of times with a hammer (but don't beat it to death). If it then cranks, bad starter.
